Well, we're off to the Moultrie GA Swap Meet in the morning, no more progress until Sunday. Maybe I'll find some Cobalt leather seats!? I re-assembled under the hood, the Master or T/O bearing is not responding. I will replace the pair while the engine is out. I did not stretch my wiring yet. I chickened out and just threw the fuse box back together. Pleasant surprise, engine started right up, in neutral. Party Time! It also starts in gear, not unexpected, but I have to hold the clutch down to start. So even with the clutch pedal depressed, the car moves if in gear. I turn the key off, shift into reverse: relight: it goes backward. Turn key off, shift into first: relight to go forward. Very clunky: but this car IS moving under it's own power, a step in the right direction! (The red 08 SS drove around as soon as we installed a Left steering knuckle, but it's still twisted up, not road worthy, yet!) Black 06, GOB-BALT, I got with no battery and the driver's window was knocked out. Inside styling rivaling a proverbial "Goat's Stomach". The driver door has every problem possible, mirror: gone, door panel: in bits, window: shattered, lift motor: wiring hacked, door panel: MIA and the exterior handle is flexing the area around it, thus ripping out of the sheet metal. This car came from a used car lot, it came with 4 keys! I thought, Great! Thanks! Actually 2 of them fit nothing
, one ignition/trunk key and one driver's door lock; passenger door lock cylinder is MIA. I'm hoping to find a J/Y door/trunk set, a new set with Ign is probably a little expensive. Passenger door panel is in 5 easy pieces. Inside rear view mirror is de-silvering from the edges in, so trash. Windshield is dern near perfect, wow. I have located color matched, door mirrors! Electric!, but they don't seem to work. Happily, all four wheels touch the ground in unison, most of the time. 4 lug A/M Falken(?) alloys with hex key type lug nuts, uuuugh. The aughts called and they/them want their Racerr Boi lug nutz back.) It goes forward and backwards. I cannot say that for $500, With a Title! and Towed to the farm, that I chould have expected much more? It's major redeeming feature beyond the Title is that it IS all one color AND it has NOT had it's Cat stolen!(a minor miracle in this price range!) Today I fitted a J/Y ft SS bumper cover. The headlights are foggy and their fit hooks on the bottom are smashed, I re-installed them anyhow. One works! Oh! then I was picking up my dropped tools, climbed under the front and found that the radiator is bent!, on the bottom edge, right in the DERN middle making a shallow V BUT it's not leaking!! So I'm sure it will leak as soon as I straighten it so the fan will fit again. Of course I failed to notice this bend until AFTER I installed the bumper cover, Arrrgh! That job is easier with the bumper cover off.
