- enjost Member
Occasionally while driving the rpm gauge will go between 0 rpm and the expected engine rpm. Fuel will read low. When this happens sometimes the immobilizer light will come on (yellow lock on cluster). Then if I shut it off when the immobilizer light comes on the car won't restart then will let me restart again after a minute or so. This is with a LNF donor. It seems like some kind of grounding issue or maybe a loose wire for the cluster but I'm not sure where to look first. The harness was modified by DF for the goblin.
The car drives fine but I'm worried about the immobilizer issue causing me to be stranded.
