V1 NEED HELP!! OBD2 Not Connecting and Does have Power
viperbmw69
Active Member
V
I was able to connect to the OBD2 port yesterday and everything was working fine. I unplugged the ECM to fix a speed sensor wire and plugged it back in and now I get no connection when I plug in my OBD2 scanner. I see Grounds on both grounds on the DLC port I have 12v on red power. I have 2.5ish on Brown/BLK and 2.5ish on Brown wire This is all with the key in the On position.
I tested my OBD2 on another car it its working fine.
I get 120 OHMs resistance from the EPS unit and I get 120ohms resistance from the ECU. I checked the wires and all the wires are showing good continuity for the GMLAN and power.
STILL not connecting
