V1 Transmission removal process
Stingray
Member
Gents,
I believe I've got a leak under my new throw out bearing or the input seal. I thought it was just brake fluid dripping from the clutch pipe seal but it looks like oil is getting thrown back on subframe and exhause each time I run it a bit. It'll leak for a few days after and then stop. Is there a process listed on steps I need to accomplish to drop engine and remove transmission documented anywhere?? Else I'm just going to start removing everything and basically start over. Thanks!!!!!
I made this for myself.... It's not a how-to but rather a checklist for me to remove the engine. There may be some sockets/wrenches with the wrong size listed and is for a Supercharged version. I also just set my engine on a roller dolly that has wood blocks setup to hold it well. I then lift the frame off the engine/dolly.
comegetjoe
That's nifty to have on hand.
