Wanted - Upper bolt for BCM kick plate
comegetjoe
comegetjoe
Does anyone have one lying around they could send my way?
In a bit of confusion back in the day, I cut mine short and it will no longer reach through to support the kickplate.
Is the stock setup not just a bolt with a nut through the firewall? I didn’t like that so welded a bracket to the frame so it was a lot stronger in case it got really kicked.
But if it’s just a bolt with nut, just pick a bolt that will go through the spacers and measure the length as needed. And get a nut to match the bolt. You are building or have built a car, I have confidence you can figure this out.
But if it helps, I’m pretty sure a common 1/4-20 bolt will work.
comegetjoe
Thanks man! Lol
