Search on here for “aeswave”. It will lead you to link I have posted multiple times for explanation of how high speed works and a basic test.
Issue came back and I have time to play with it. So I checked across the 6 and 14 pins on the DLC (OBD-2 port)
I get 60 Ohms across pin 6 & 14 with the key off.
With key on I get .2 Mega ohms (or I get 0.2 set on the 2 M Ohm setting). It's 'OL" on anything except the 2 M ohm setting.
Started pulling the main three off the system, all with out power connected. Each one of these is only disconnecting the the one item.
Disconnecting the BCM gives 120 Ohms.
Disconnecting the PCM gives 120 Ohms.
Disconnecting the small Power Steering plug gives OL.
Any advice in what this all is telling me? Or, next steps to try out?
