Do your lights all work? Turn signals, headlights, brake lights?
When you turn the key to the "on" position, does your fuel pump prime and does it sound like the engine will start if you crank?
If that last question is a yes (pardon me, I didn't take the time to read back in this thread), then make sure you're in neutral, turn the key on, and jump the 12v pin on the starter. That should result in an engine crank.
I had similar problems as you, and my problem ended up being poor contact between one of the fuse box block connectors and the pins inside the fuse box. There was one pin in there that the ECM was grounding at crank, but since the pin wasn't making good (or any?) contact, the crank relay was never receiving ground and thus, no crank. I fixed it by splitting the fuse box and bending many of the pins slightly to force better contact. Unfortunately these connectors were not designed to be separated and reconnected dozens of times.
