Is there an adapter that converts a 4 lug to 3 lug on the bearing hub?
No so the knuckle and hub is a 3 lug, but the axle and hub I’m going to use for the k series is a 4 lug…. I’m wondering if there’s an adapter for that change or am I going to need one fabricated?Are you trying to find, a hub that matches your drive shaft spline count?
I assume you're planning to use a Cobalt rear hub (4 bolt) on the front of your non-Cobalt Goblin. If not... good luck.No so the knuckle and hub is a 3 lug, but the axle and hub I’m going to use for the k series is a 4 lug…. I’m wondering if there’s an adapter for that change or am I going to need one fabricated?
I’m trying to reach out to df goblin to see if they can make me custom knuckles, I’m sure the axles I want they can do a custom length shaft as I read in the descriptionI doubt that all 4 hole knuckles are the same. And I don't know how you could make a hub adapter that wouldn't change the required axle length more than the axel will want to extend. So that will take digging for a longer axle or a custom axle. A custom knuckle might be easier.
They made the subframe for Justin reed to test out and now trying to put that for market, would be smart to do the knuckles if they plan on doing another version that involves a Honda motorI don't think DF is doing much one off custom work at this point, they have their hands full. Of course, if you throw enough $100 bills at them...
i know ima do custom axles for the right length, and i ordered the tubular subframe., i think ima have a problem with the hub unless i get a custom fab adapterOkay, other thoughts going forward.
The Honda has a different wheel track width than the Cobalt. Therefore the axles probably will be different lengths. So, from you first post pictures of parts, the control arms may not be the right length already and you will have to make your own.
I would say, personally, that DF will not do a one off project. Although they did make some axle stuff for the Tesla Electric Goblin. I for sure wouldn't do it since research/development and an unknown workable model could be made with one attempt. $$$$$
Or, use a known other model Honda product and make that work for you. Like the attached link!
Front Right Steering Knuckle & Wheel Hub Bearing Assembly for Honda Pilot 05-08 | eBay
Knuckle Steering. Hub bearing. Honda Pilot 2005-2008 V6 3.5L Sport Utility Front Right. Item Type: Wheel Bearing and Hub Assembly. Item Type Wheel Bearing and Hub Assembly. Power Steering Rack. Wheel Stud Quantity 5-Lug.www.ebay.com
And last, make your own subframe and ditch the Cobalt cradle!!
