Yes unplugging evap wiring disables LTFT on LNF.. The reason to disable it is that the LNF LTFT is a very simple routine and is one number applied for all engine conditions,. If you are running a little rich at cruise and idle, it will pull fuel at WOT and might have to try and add it with STFT. I’ve seen some that make sure the LTFT is adding fuel overall if they are running it. I have pretty much had mine disconnected for 2 years.
