Took it for a 30min spin today. Adding 1.44x on the MAF makes it idle, not 100% perfect but decent enough to call it idling.
I'm not entirely sure I understand how to tell if I need additional adjustments to the MAF main freq +/- regarding the new placement of the MAF and the fact that it's blow through. To know if the scaling is good enough to start doing ST/LT fuel trims.
Should the idle Hertz be in a specific area or something?
Other than that it's incredibly twitchy at low throttle. Sometimes hard to look like I know how to drive a manual which is obviously a blow to my awesome manly ego, lol.
Anyway, progress is progress.
To do MAF (mass air flow) tuning, you are going to need to set up VCM Scanner tool and the VCM Editor tool for your engine.
The high level concept to MAF tuning is:
- When the engine is up to temperature and running, use the Scanner tool to log the wideband's observed AFR (air fuel ratio), compared to the ECM's requested air fuel ratio. The difference between these two is the AFR error.
- Once the error is collected from a test run (driving 5-15 miles, or maybe just near idle in the beginning), then you apply an error correction to the ECM MAF table, based upon the AFR errors collected.
Here is a VCM Scanner log file of mine.
The left window has the parameters that I was logging. The highlighted line is my AEM wideband, showing a .96 lambda at the moment. 2 lines above that is the AFR commanded by the ECM, which is 14.70 at the moment. 14.7:1 is equal to 1.00 lambda, so my engine is running 4% rich in AFR at this moment.
The top right window has a chart of the collected AFR errors, broken down by the closest Hz reading from the MAF sensor.
The highlighted cell is showing -7.3% error (running rich AFR) at 3600 Hz MAF frequency. This is my average error at that frequency during this test run.
What you need to do to start MAF tuning:
- Connect the MPVI to the OBDII port, and your laptop, with VCM Scanner running. Does the software connect to your car? Can you start logging data?
- Add your wideband to the parameters on the left that are being logged. Also add the AFR Commanded by the ECM. Maybe some other useful info, like RPM, Throttle position, speed, etc. Try to keep it under 20 parameters logging, so it doesn't get too slow at logging data. Can you find your wideband O2 sensor? Is it showing valid data? (mine needed to be divided by 10 to get lambda)
After you get thru these first steps, we can talk about setting up VCM Scanner math parameters for calculating error percentages, and VCM Editor stuff to put the engine in open loop and settings for MAF tuning.
Do me a favor, and tell me where you are currently. Have you installed VCM Scanner software on a laptop?
