I finally have what I think is a good hose for the coolant tank. Its hose
#88429 I did have to shorten it and add a connector in it.
Since its available....I powder coated some smaller stuff. I think I am going to remove the subframe and paint it a semi glass black. Itll match better.
I installed the brake lines, clutch line and started looking at the steering. Does this set up look correct? I still need to put clamps on them. I had to put the reservoir on the lower holes of the petal box. my grounds aren't long enough so basically everything was getting in the way. It looks a little tilted in the picture I am not sure if its as bad in person. Maybe I'll end up having to make my own holes in the petal box to make it work.
Lastly, I am not sure I kept the longer pipe that goes onto the power steering shaft. Essentially what all of our steering parts attach to. Anyone have an extra one? I looked online, I don't think its a part you can order without getting the whole steering column unit. I'll prob reach out to Adam since they have a bunch of cars.
