That'd be great, I've dabbled on YT a bit but I still don't fully understand how it works.If you want to get into tuning, we can give you some pointers. I'm even less of an expert on troubleshooting electrical issues than tuning, though, unfortunately.
Aw dang, it was kind of a long shot, oh well. It started after my ecu came back from ZZP and installed it in the donor, like the rich STFT issue so maybe I can do something about it in the tune? It doesn't go off every time, but sometimes it goes off for like 30 seconds, I can hear the relay clicking on and off just like it did in the donor, thats how I can tell what it is with no lights installed. So maybe it's the relay, but I can't pin point which one it is just on the noise alone. I'm gonna have to turn the ignition and pull them 1 by one until it stops I guessLimp/Reduced Power mode doesn't have anything to do with flashers.
Polish them but I would recommend replacing the rubber rear bushings with metal ones from Moog or OTTPAnyone powdercoat the control arms and did you press out the bearing and remove the rubber first?
This is awesome but I don't have the time or patience to get this quality finishPolish them but I would recommend replacing the rubber rear bushings with metal ones from Moog or OTTP
I considered that. I may just spray them with a solid few layers of primer underneath, clear coat on top and hope for the bestPowdercoater may not want to do it with the ball joint still attached since the amount of grease might contaminate his oven. And won't be good for the ball joint either.
I sprayed mine and it chips. I just touch it up every few thousand miles.I considered that. I may just spray them with a solid few layers of primer underneath, clear coat on top and hope for the best
I'm still waiting on stage 2 and 3 to arrive as well but I have these, https://a.co/d/2FggnfL, in my cart. They look similar to the rigid brand lights I have seen on a few Goblins but cheaper in price. Ill have to make my own bracket if i go this route but shouldn't be too hard.Update: first start
Still undecided on the intercooler and intake setup for now. Also have stage 2 and 3 ordered. I have enough small things to do that it should keep me busy until then though. Been looking for tail light options and ideas. Leaning towards modifying side by side tail lights...Show me what you've got!
Video 20:
Those are cool, I was looking at side by side lights on Amazon and I got the wiring figured out with a relay to add a turn signal. Just gotta pick ones I like and figure out how to mount them since they're clip-ins not bolt-ons. Gonna do a write up probablyI'm still waiting on stage 2 and 3 to arrive as well but I have these, https://a.co/d/2FggnfL, in my cart. They look similar to the rigid brand lights I have seen on a few Goblins but cheaper in price. Ill have to make my own bracket if i go this route but should be too hard.
I have these and they have been good. I did wire them to a plug end (that also is on the stock DF lights) so I can swap them out to the stock units when ever I fancy it. Super easy to install and look great at a fraction of the cost for the Rigid units.I'm still waiting on stage 2 and 3 to arrive as well but I have these, https://a.co/d/2FggnfL, in my cart. They look similar to the rigid brand lights I have seen on a few Goblins but cheaper in price. Ill have to make my own bracket if i go this route but shouldn't be too hard.
