DUNE
Recently I've been diving deep into the deep and complex waters of the aftermarket wheel & tire world lately and I've finally come up with a setup that I wanted to run past the forum and ask for opinions. Here's the setup
Front
Wheel - Hypergram 18x8.5 +35
Tire – Nitto NT05 245x40xR18
Rear
Wheel – Hypergram 18x10.5 +15
Tire - Nitto NT05 295x40xR18
My goblin will be primarily used for street use with the occasional track day. From what I read, the NT05s should fit that purpose pretty well. Tires should be pretty close to flush with rims. According to the fitment calculator I used, the setup will be 13mm (0.5") closer to my struts but I will also be picking up 1" spacer adapters to convert it to 5x144.3 Speedo error is showing to be 8%
Another tire I was looking at in the same sizing was the Falken Azenis RT660. I would love to hear some feedback & opinions from you guys on those two or other tires that you've had luck with. Im fairly set with the Hypergrams but I would be open to suggestions on the tires
Front
Rear
