KingChuck24
So today was another test drive and this time we went a little further than normal. The roads we were on were a little bumpy and it ended up knocking off the ground wire from the battery while driving. We reattached it and when we did the car went into anti-theft mode. We tried reprogramming the key about 3 times but we couldn't get it to work. We then tried to original key to the car and that one would work either.
After further inspection and going through the BCM fuses we discovered that fuse number 1 and number 22 were blown which is the 10 amp and the 2 amp. We replaced both and connected the battery and after turning the key to the run position they both blew again.
The car has an aftermarket supercharger so the heat exchanger pump is wired in through the ECM fuse on the fuse box. We unplugged that and changed both fuses and now only the 2 amp ignition fuse is blowing.
Before all this, it is worth noting that the car, before starting, would turn on fine but then when turned to the start position all the electronics would shut down and the only way to solve this was to disconnect and reconnect the battery.
Not very good with the electrical side of this but my first guess would be something to do with the ground. I went through and they are all still connected so I am not entirely sure.
Any help would be much appreciated!
