AZMoto #245 ext-track - 09 SS TC
It will be interesting to see what you think about the GPS version of the controller. I don't think anyone one here has used it. I'm fine with mine just being a manual adjust since I never wish for more assist than the lowest setting that actually works.
You will likely have to add a 120ohm resistor to your data wires during the install.
The GM high speed LAN has a + and - line. The resistor goes between those 2 wires.
It is suppose to go at both ends of the LAN. So on my LSJ, that would be the tan wires on the power steering that go to the OBDii port, which is one end of the LAN. OBDii - power steering - BCM - PCM.
Where exactly did you add the resistor?
