The lines that go from the master cylinder to brake tees use three different fittings and which ones you need depend on the donor trim and not the year. Early base model and late base model use the same lines.
M10 x 1.0 invert flare (left in photo) - base model donors, SS/SC donors, and some 2.4 liter donors
M14 x 1.0 invert flare (middle in photo) - all donors use at least one of these but SS/TC donors and some 2.4 liter donors use two of these
M10 x 1.0 bubble flare (right in photo) - used on all master cylinder lines regardless of donor. The brake tees use bubble flare because the tees are old school parts from VW
To put it another way, here are the only master cylinder to brake tee lines we produce (we used to make a shorter rear master cylinder line for standard length cars but don't anymore):
- S42B Brake line, MC front - M10 IF x M10 BF for base, SS/SC, and some 2.4 donors
- S42C Brake line, MC front, TC - M14 IF x M10 BF for SS/TC and some 2.4 donors
- S42G Brake line, MC rear - M14 IF x M10 BF for all Goblins regardless of donor type
I'll add all three tube nuts to the store on Monday.
