Do you recall what size quick connect fittings the fuel filter users? Are both 3/8" or is one a different size? I have to order a new fuel filter and planning basically the same setup for fuel lines, but I'm not sure what size quick connect fittings to order. Worst case I'll measure when my filter gets here. Thanks!I also used rubber fuel line to go from the pump to filter.
It was actually cheaper to buy the whole range of quick disconnect tools than just 1 or 2 units. 3/8" is the only one I used, but I did have issues getting some hoses off. I think those were the push button release units though.Do you recall what size quick connect fittings the fuel filter users? Are both 3/8" or is one a different size? I have to order a new fuel filter and planning basically the same setup for fuel lines, but I'm not sure what size quick connect fittings to order. Worst case I'll measure when my filter gets here. Thanks!
I don’t know. I reused the fittings from the stock fuel lines. Warm up the hard plastic hose enough so you can pull the fittings off the end. You can use a razor to cut the line, just make sure to don’t damage the fitting.Do you recall what size quick connect fittings the fuel filter users? Are both 3/8" or is one a different size? I have to order a new fuel filter and planning basically the same setup for fuel lines, but I'm not sure what size quick connect fittings to order. Worst case I'll measure when my filter gets here. Thanks!
