As promised here is what I am working on:I'm working on something that I'll hopefully be posting here in a couple weeks. Hold me accountable lol.
Basically, side pods with cheaply available parts that are attachable to any frame with no modification. That's the goal anyway.
Is your setup just one unit in the rear or do you also have the stock DF unit in the front?Here’s what I did for mine
I had both hooked up before but bypassed the front and there was no negative effects from it so it’s been un hooked ever since thenIs your setup just one unit in the rear or do you also have the stock DF unit in the front?
Do you have any pictures up close on what/how you mounted the radiator to the frame? ThanksI supercharged a 2.2 after build, so I put mine behind the passenger. It has a fan on the back pulling air through. You could easily use this as a secondary location.
That helps a lot. Thank youI got a kit of insulated clamps and went to town with different sizes until I found the perfect fit. It's rock solid.
And don’t have by chance the item number for the pressure cap?I got a kit of insulated clamps and went to town with different sizes until I found the perfect fit. It's rock solid.
You bet!And don’t have by chance the item number for the pressure cap?
That is great! Thank youYou bet!
