CaptFrank2001
Is there a way to wire the dimmer for more brightness? I can not read my coolant temp, fuel range etc... in daylight.
Those DIC messages aren't really daylight readableIs there a way to wire the dimmer for more brightness? I can not read my coolant temp, fuel range etc... in daylight.
I can read mine just fine if I cycle the auto lights to off…. In for a fix since I didn’t build…. It’d be cool to have a day/night flip… or just keep the dimmer and mount it.Those DIC messages aren't really daylight readable
Yes, I have a new Ambient Light Sensor. If I cover it up nothing changes.Are you using the ambient light sensor? I have the same problem, and have been assuming that the gauges are dimmed because the bcm thinks its dark.
And actually exposed to sunlight? I installed a new one but have never actually mounted it so it's under the hood.Yes, I have a new Ambient Light Sensor. If I cover it up nothing changes.
Mine is exposed to direct sunlight and the dimmer is set to max brightness by wiring it as directed in the wiring guide. My previous comment was based on my experience with other GM vehicles of similar age. The shroud/visor over the cluster helped in those applications (as did a full roof), but direct sun didn't mix well with those displays.And actually exposed to sunlight? I installed a new one but have never actually mounted it so it's under the hood.
The video shows the Purple & Green dimmer switch wires to be soldered together. This has been done so I assume this is setting it for max brightness which I do not have.Mine is exposed to direct sunlight and the dimmer is set to max brightness by wiring it as directed in the wiring guide. My previous comment was based on my experience with other GM vehicles of similar age. The shroud/visor over the cluster helped in those applications (as did a full roof), but direct sun didn't mix well with those displays.
And that is screen brighter than night time?lighting goes to daytime brightness
Affirmative. Now the way my goblin is wired doesn’t seem to matter with the light sensor…. But when turning the auto lights to “Off” it goes to daylight mode; as shown.And that is screen brighter than night time?
I actually haven't verified that my ambient light switch is affecting the headlights either... they just seem always on. I'll check that tonight. I'm gonna mount a little ODB dash module, and i'm planning on putting some 12mm turn signal/high beam/oil pressure light indicators so it's way more visible to me. I drive for miles with my signal on, lol. I plan to 3d print the bracket and have it go thru the old holes for the turn signal bracket. My ambient light sensor will go above that, and actually have consistent visibility. I plan on swapping headlights to some with halo's or such for "running lights".That is how mine works. Withe the headlights in AUTO or ON the instrument lights are dim. When I manually turn the headlights to OFF the instrument lights get bright. No matter what I do to the "Ambient Light" sensor, nothing changes. Also tried another sensor & no change.
It would be nice to have bright instrument lights independent of the headlight control. The dimmer switch in the donor is wired to the BCM (small plug) by the Purple & Green wires that are soldered together when prepping the wiring harness. I am guessing I can purchase a stock Cobalt dimmer switch & re-wire it to those two wires and then see what I get.
