Putting the electrical back together after the trans swap and had a weird electrical issue. When I was hooking up the negative cable to the battery it tried to fire the starter which tried to turn the engine over.
The vehicle did not have the fusebox installed, did not have to large 50-amp under hood fuse or B+ cable attached to the fuse box.
The negative batter cable only goes from the battery to the ground post on the side of the battery box.
I think I might have a negative battery hooked up to the +side of the starter. Is this even possible?
