ToothMagician
Can use the PWM signal for a boost control solenoid or 3 port boost contol solenoid?
Seems like I got a decision to make on 1 and 2...1. And 2. I have not. I didn’t want to tap into my intake manifold. So that stopped me.
3. I think the reservoir plug goes directly into the tank so it would gush fluid out if removed. I also think the second one I bought from RockAuto when I thought about doing an Option B even came with the sensor already in.
4. I think DS is right about the first two. The third plug is the Ambient Sensor plug. Just mount it anywhere.
5. The DF unit is adequate for street driving. For track I shall defer to the guys that have done more than hard parking and street driving to answer.
@Sluggonaut, so you just have 2 primary reservoirs and use the second as the option B tank? Do you think the non-SS reservoir is the same or similar enough to work?1. I bought a new coolant overflow tank for $20 on Rock Auto right before they went unavailable. I only did that because someone gave me $50 for my Option B tank and the mount. I bought a second driver-side mount from DF to mount it. I used the driver's side because I am not using an engine cover and it allows easier access to the oil dipstick.
2. That's the same question I had. It can just vent to atmosphere and does not need to recirculate. I have yet to have anything come out of that tube after 2 seasons.
Here is a pic during my build that shows it installed using the driver-side mount and the tube running straight down:
Yes, I am using a primary reservoir as my Option B tank. I don't think there is anything special about the tank, so any coolant reservoir should work.@Sluggonaut, so you just have 2 primary reservoirs and use the second as the option B tank? Do you think the non-SS reservoir is the same or similar enough to work?
What are you using for cooling, the stock DF Heat exchanger?
Is that good enough for auto cross and spirited driving? Are you monitoring coolant temps by chance?Yes, I am using a primary reservoir as my Option B tank. I don't think there is anything special about the tank, so any coolant reservoir should work.
I am using the stock DF heat exchanger setup with NACA ducts and no fan.
Solid, Thanks this gives me good info to go onI haven't auto-crossed, but with spirited street driving at 12 PSI my IAT2 temps were fine. I haven't logged since getting my boost controller configured and running 22 PSI. That's on the list for things to do once driving season starts and it's warm enough for the tires to stick.
The last log I have was when I was running ~ 12 PSI on my K04, with IAT at 93 my IAT2 was 100:
Good suggestion, but I'm not getting the whirrrrrrrrrr sound when trying to jump the pump with the wire. It only makes a clicking sound. No fuel in the line when I checkedCheck to make sure you have the relay in the fuse block in the right slots. There are 6 slots in the block and 4 pins on the relay, so 2 ways it can go in.
