I have a few questions to add to this.
The ABS connector has wires for the wheel speed sensors. I take it between removing this connector, and having to modify the rear hubs for use in the front, there is no point in keeping any of the wiring for the wheel speed sensors?
There are also 2 wires that go from the ABS connector to the brake booster plug. Just remove those wires from the brake booster plug? Or is that connector also not needed?
I assume the wiring and connector for the yaw rate sensor is also not needed?
And finally, with no wheel speed sensors, I assume traction control does not work, and there is no reason to keep the traction control button from the dash harness. Correct? No "performance mode" with launch control either?
