V1 Aerodynamics
Waterdriver
I kind'a got a scan today? Lol
Unless Lonny announced at the Goblinfest that DF is adding front wing mounts into the Store, all front wing mounts are custom fabrications to fit a builders wants and needs and for the specifications of the wing being used. Do you have the skills and tools necessary to fabricate mounts? If not there is likely someone on the forum who may be able to replicate mounts they have made. But be ready to do some welding, as bolt-on mounts may not be feasible. :D
Here is the short frame from Lonny. DF was playing with the rear engine mounts at the time, so the tubes there are a little off from our production frames.
36213
36214
36215
The file is too large (10.9MB) to put out here on the forum, but I can email it to you if you want.
It is a CAD file with a *.SLDPRT extension on the file.
Update: The file has been converted to an STL file, now 32.8MB, DfGoblin Frame.stl
Need a 4 corner scale to make the CG measurements. Weight of each corner is taken, the rear of the car is lifted 10 inches and the weights on the 2 front scales is taken. There is a formula that these numbers are plugged into to get the height and fore-aft position. There is an on-going forum thread with this request, that gets refreshed by me every several weeks. :rolleyes:
jennam
Ouch. These are the ones I’ve been eyeing. 1250lbs per corner should be plenty of capacity for a goblin
ProForm 67650 Vehicle Scale System Kit with 14-1/2" x 9-1/2" x 2-1/2" 4-Scale Pads - 1,250 lbs. Capacity Per Scale https://a.co/d/1bxpUl9
I’ve looked at all kinds of other scales to try and find something that would work and be cheaper but haven’t found anything yet. Bathroom scales don’t have enough capacity for the rear. 800lb capacity shipping scales are $150-200 each.
Waterdriver
One can hope, but I can't get anyone to get the CG measurements made. :( Getting an aero profile done might be almost impossible. LOL! :cool:
Given the corner weights some have shared like Ccnax, Maybe this calculator gives you the approximate CG.
Of course anyones Goblinbuilt with different components will be different, and of course yours with all those speed holes. Lol.
Hope this helps.
Site is RacingAspirations.com . All kinds of calculators to make your mind turn to goo.
The various weights supplied by several builders has been used to locate the fore-aft CG location - directly under the fuel tank, give or take an inch or so depending upon which model. The measurement to locate the vertical CG is the critical one that is needed. This requires lifting the car a specific height and the weights of the two tires on the ground to determine the vertical component. This must be known to set up the suspension geometry correctly.
See this discussion for the CG measurements thread Goblin Center of Gravity in general discussion - so we don't hijack this discussion about aerodynamics any further.
