You can always sell it in the future if you don't end up using it. Do you have the space? It will probably cost you less than the ZZP supercharger upgrade kit, and an 09 LS donor can always use the upgrade, right? LSJ swap the world!
Hard to say if it has shifted the engine and if there would be any damage to mounting tab, etc. Otherwise at 120K, it could potentially be a very good donor. Can you see it in person?
Pro - second source of donor parts if needed, second engine and transmission if future performance or appearance mods are desired can minimize downtime, second donor on hand if the desire to build again comes.
Cons - unnecessary expense, having a second donor encourages building a second Goblin (see Con #1)
