V1 Canyons trackframe LSJ-T Htown
JSATX
If I recall, Lonny also had me check to make sure the throttle butterfly moves when the gas petal is pushed. If not then there is a communication problem between the BCM and the ECM. I made the mistake of cutting out the tan and brown twisted wires without soldering them together to keep the loop going. It's easy to forget when you remove the ABS or airbag systems as they go through those 2 big connectors.
Nuker-
My throttle butterfly worked even when the data lines were cut for what that's worth.
canyon bolieu
Okay so I had the tan wires backwards from the bcm to the ecu mine weren't in the same place as JSATX but I found them and I had the tan with black spliced into the tan one somehow so I flipped them around and boom started!!! For a couple seconds cause turbo plumbing isn't on but oh well! How do I post my video??
Locate the tan, tan brown twisted wires at the OBDII and at the ECM. These are data wires that daisy chain from one system to the next collecting and passing on information all the way from the OBDII back to the ECM.
Check the tan twisted wire for continuity from the OBDII to the ECM. Then do the same for the tan twisted wire with a brown stripe.
If they do not have continuity you will need to trace them back through each system.
They start at the OBDII and then go to the power steering, BCM, through the tunnel, to the TCM (on automatics) and then to the ECM.
canyon bolieu
I found out the problem and it starts now but only for a little cause the turbo plumbing isn't on. How do I post the videos on here? And imma be begging you guys for the rest of the stage 2 and stage 3 parts now lol
P
Set up an account on YouTube.com (or Vimo(?)) and once it has uploaded to the service, you copy and paste the resulting URL to your post.
canyon bolieu
Nuker-
Hey can you tell me what color the two wires that are for the coolant resivor sensor. Can't seem to find the right one
canyon bolieu
So somehow my coolant resivor plug ended up in the middle of the tunnel so I'm gonna have to extend that backwards but I found it
canyon bolieu
Canyon - what kind of paint did you use on your engine? I really like the way it turned out.
Just some black engine enamel rattle cans or brake caliper paint. Me and a friend got 2 corded drills and got a couple of different bits for it and about 2 hours later it looked brand new then I sprayed it down with brakleen and painted it I'd say I used like 4 cans then 3 cans on the trans
canyon bolieu
Did anyone else have problems with getting an obd2 reader to work? Mine seems to get power but the screen on mine just keeps flashing and nothing ever comes on. The power steering is plugged in everything that connects the twisted wires is plugged in. Is there a fuse that could be connected to it? I hear a click from the fuse box but I can put it to a certain fuse
Silverback
Thanks, neither of my cheap eBay wifi or Bluetooth OBD readers worked on the donor, but O'Reilly could read and reset codes.
SliderR1
Brian - which manual is that picture out of? Reason I'm asking is that I have conflicting data on the OBD2 pinouts that I found on EFI Live's Bench Harness Tutorial for a P12 Atlas PCM for the '05 LSJ. And all of the serial pinouts on their tutorials (for the older PCMs) are shown to Pin 2 on the OBD2 connector.
