- Rauq Goblin Guru
The LSJ oil cooler has two hoses that run to and from dedicated ports on the thermostat housing. The LNF runs tees on the coolant return line and the hose to the return tank, circled in green. Before you figure out your fuse box mounting, make sure you have a solution for that second (currently unconnected) tee. It should run to a tee in a hose that goes from the top-facing barb on the thermostat housing to the coolant overflow tank. You can loosen those clamps and rotate the tee to face upwards, but I'd hate for you to figure out fuse box mounting and then have to redo it to accommodate for that tee.My hose takes a different route (in yellow) but I also have a SC version. The fuse box sits on top of the radiator hose and just barely (and I mean barely) misses the shift levers. It connects to a port right on the thermostat hosing. I also do not have that extra port pointing to the shift mechanism. Where does this hose (with green arrows) go?
Again, mine is a LSJ so this might be drastically different.....
Also, my frame is a newer design and we didn't have to mount the black plate to the frame. It was already welded in place.
I started with an LSJ donor but now have LNF-esque cooling hoses. My kit came with a spacer here, not sure if you have that or how much of a difference it'd make.
