- PHerder Well-Known Member
Somewhere in the back of my mind is a note that if the engine or the electronics (PCM or BCM) is changed then something has to be checked/configured/? to make the electronics work with the different engine. (i.e. same type engine - 2.0 LSJ)
Anyone have any info on that? I do know that in the PCM, the VIN is entered into the memory so if that was changed, the VINs wouldn't match. But if the engine was swapped out (i.e. for a lower mileage version for example), is there something like a crank timing that the PCM needs to be configured for?
Inquiring minds want to know...
