A At4Connor Member A At4Connor Member May 23, 2026 #1 Can anyone show me where the coolant return line hose goes on a supercharged engine?
Rttoys Smokin' Goblin Rttoys Smokin' Goblin May 23, 2026 #2 Here’s the best pic I have And you can see part numbers on them.
A At4Connor Member A At4Connor Member May 23, 2026 #3 Sorry, I was meaning the return line off of the coolant reservoir itself. The little line.
Ross Goblin Professor Ross Goblin Professor May 24, 2026 #4 The white dotted line goes to the coolant overflow tank. It is off of the top of the thermostat cover. Pic 4 in this post.
A At4Connor Member A At4Connor Member May 24, 2026 #5 This is the line I’m referring too Attachments IMG_2683.jpeg 144.8 KB · Views: 38
David Goblin Guru David Goblin Guru May 24, 2026 #6 At4Connor said: Sorry, I was meaning the return line off of the coolant reservoir itself. The little line. Click to expand... I used @Ross post picture. Not sure if your referring to the small line on the top of the coolant reservoir.
Ross Goblin Professor Ross Goblin Professor May 24, 2026 #7 That little line goes to the metal tube I put a yellow line on. It is below the fuel line, that I put a red line on.
