David
- David Goblin Guru
So I just bought a Goblin and trying to slove some issues. That seem that where never completed correctly. Need some suggestions on a way to execute the cooling system.
I have a attached the plumbing sketch of the way its piped up. Here is what my question are.
1. Is it the best way to have it plumber up?
2. Pump is not connected
3. There are two fans behind the DF heat exchanger that weren't wired
4. Option B tank is below the W/A cooler, should it be higher?
5. When does the pump turn on? I believe i read its always on. Was thinking if I install a sensor and wire it up to turn on at a certain temperature. While activating both fans. Or just leave the pump run as the OEM way, and wire the fans to turn on at a certain temperature.
6. Oil cooler is behind one of the fans. Meaning the order from how the air will hit them is. DF heat exchanger - Fan - oil cooler. Should the fan be behind both exchangers?
