V1 Custom Ignition Switch Electrical Adapter
Lando217
9 boards ready to go (the picture below is before I put them in heat shrink). I have PM'ed the 7 people that indicated they were interested. I have 2 (possibly more) unclaimed boards. If you are interested for $45 shipped, let me know. I do not have plans to make another batch of these in the future.
Same here payment sent thanks!!!
Anks329
Same, paid this afternoon and sent my info over. Thanks for your work on building these!
Ok, sharing out this design for anyone who wants to build your own. I will not be answering questions or providing support. You can order the PCBs from OSHPARK as I have shared out the board design. www.oshpark.com Click on sharing, then search for "Goblin Ignition Adapter". Oshpark allows you to order the boards in multiples of three.
Attached is the BOM from Mouser for enough parts to populate three boards. I think the BOM is missing the part number for the crimp pins to use with the two pin connector. If I can find it ill update this post.
jennam
Thanks for sharing. I'm almost done with my engine swap and I've been waiting for that to be done before I start making modifications to the wiring harness. My old keyless system I was using was dying so it didn't get moved to the new harness.
Fully understand, since this is a very part time project you are basically doing from the goodness of your heart. We can only wait in anticipation for you to have the time to work it some day. Thanks for the update - and hopefully you can get back to your Goblin sometime soon.
RGSkid70
I built three on these gadgets (OSHPARK minimum buy) and have since decided not to bother with a push-button start or key fob. Free to anyone who wants one; you pay only postage.
I've already got my ignition switch mounted and everything works fine. I didn't see much value in replacing it with a push button/key fob. Lot of work for little/no gain.
Suit yourself! All the ladies are impressed everytime I start the car with my thumbprint though. ;)
RGSkid70
If anyone else wants to build one of these, FYI the Molex terminal p/n is 43030-007 terminals (23 cents each at Mouser.com
