One of these days I will open up my panel, and cut the traces Chad mentioned.
I will trace & document the ABS light trace then... but here is some notes to help me:
After I took these images, I realized I shouldn't have covered the check engine light, so I went back and removed the tape off of it.
I should be able fix that in HP Tuners.
Or we could wait for Brad to finish his next Goblin gadget and select which light we want to disable.
Goblin Warning Light Eliminator (Airbag, Seatbelt & Tire Pressure + Bonus Features)
Would be good to make this switchable if possible to accommodate both ways to build - if too difficult turning this off gets my vote. :) All of the features can be enabled or disabled from the menu. You can see it in this video from November:dfkitcar.com
As I sit here cutting these traces all I can think about is the Iphone headphone jack hack!Here is an updated version to include the trace to remove the BRAKE indicator on the dash. The BRAKE will light and stay on if your donor had ABS and now no longer has the ABS controller.
Cut copper traces on the boards should be coated to prevent oxidation - clear nail polish works. 12 and 5 VDC signals have little tendency to create cross-trace signal paths (dendritic) with the low current signals (or ground signals) to illuminate the indicator lamps. These signals are not frequency dependent to illuminate an incandescent indicator lamp. Trace cutting, if done correctly without having copper smearing between traces, should be safe to perform.
I believe that several builders have cut board traces to eliminate these indicator lamps. Don't recall seeing any reports of issues after the fact related to trace cutting requiring the dash panel board replacement.
