V1 Donor too good to be true?
Dakota8800
Oh wow! Looks like something from my childhood at the county fair demolition derby.
Cobalt battery was always in the trunk.
Rear suspension does not get used on the Goblin.
Hopefully you will not need to replace too many major items in the build process.
SO - get after it!!!! :)
Shows you how much of a novice I am when it comes to this project!
I appreciate it! Will get the kit ordered as soon as I save the money!
Now, I find out if one of my friends will let me dirty up their place!
A first thing get or borrow a label maker before you disassemble anything. Label EVERYTHING. And take lots of photos.
Everyone says to label everything, which I agree, but to me it’s even more important to take pictures. Fuse box connectors front and back, random under hood, dash, top, bottom, inside and out. You never know what you need and a simple pic can explain a lot.
Dakota8800
Thanks for the advice! I will probably have over 100 pics after stripping.
I planned on using painters tape and a sharpie. On par with a label maker or would sharpie fade?
That’s what I used and it seem fine. I also used number and letter markers that electricians use, then made a key to know what they are for.
Tape will pull off when pulling the harness out through holes. The advantage with label maker is it is small.
As Tim said. Even if the plug is not attached to anything. Give it a number or letter and make a note of where in the car it was located. An example my car was a 5 speed. It had the plugs in the center console for an automatic.
Dakota8800
Understood! Look like I'm going to get me some labels.
