DOT Windshield and Hood for sale...
BAR-AIR
BAR-AIR
Good Evening,
Kind of changing gears... Initially was going to swap out the windshield and hood that is on BLUE and put them on Nathan’s frame. (First issue is the roll bar on the earlier frames has a slightly different angle - not a big deal couple of spacers -). Then Nathan saw the new hood which he likes a lot ( next issue is the hood was set up for the VEE’d windshield which works great but he wants to be able to have a roof and a roof rack on his car. The VEE’d windshield doesn’t set up well for that ).... So instead of swapping everything from BLUE I am thinking about reworking the mold to except a similar windshield and roll bar that is like the one on BLUE...
So I am looking to see if anyone is interested in the VEE’d windshield ( laminated glass DOT AS1 with a powder coated aluminum frame clamp on style which can be raised or lowered depending how high you want it )... the hood is an epoxy resin fiberglass quite a bit lighter then the DF hood still needs to be trimmed and fitted would also suggest adding another layer or two on the sides, initial thought was to form an angle so the hood actually sat on the upper tube... Hood will also need surface finishing nothing crazy...
VEE’d Windshield as mounted on Nathan’s frame ( as stated earlier it can be raised a couple inches if wanted higher )
Fiberglass hood set on Nathan’s frame ( as you can see the hood still needs to be trimmed and finished - also depending how high or low you want the frame will determine the inner angles if so desired )...
ASKING $1500 plus shipping ( probably better to pick up if able )
THX,
Bruce
