V1 Dragon Motorsports 1.0 [Extended\Full-Cage\Double Door Bars] - [Frame #290] - SOLD
Jareth
Started laying out the floor pan but was a little confused, did not realize at first that is now a two piece pan.
Instead of using silicone between the floor pan and the frame I decided to use a few rolls of this.
Here is a video of me applying it.
My Goblin Build - 14
https://youtube.com/channel/UCEn-zYTbTKGZSdxmppT7Miw
Jareth
Seems like it will work, I have it taped down on all the bottom surfaces but have not riveted on the pan yet. I have moved back to working on the wiring harness. Most likely won’t know until I have it on the road and see if it makes any noise?
Jareth
My Wheels & Tires came in so because I don’t want them sitting around collecting dust I threw them on what may become donor two someday. I’ll move them over to the Goblin when the time comes.
was able to use the following device I picked up off Amazon for $11.50 and had all 4 TPMS registered in less than 45 seconds. Local tire shop wanted $50 to perform the learn process.
Jareth
Am I correct that this bracket is not need for cars with automatics and will also interfere with the footwell cover? I can cut it off?
Jareth
Thanks guys, seems like a waste of effort to have it welded on there when you specify during your order that you have an automatic.
