SwerveMonkey
- SwerveMonkey Well-Known Member
I am considering converting the brake system over given the lack of availability for early model parts, I'm not sure if anyone else has decide to take this path.
I thought that swapping over would mean less chance of being in the same predicament with my early model woes.
Tried to search through forums to see if anyone else has done this other wise I'd volunteer to do a write up of sorts detailing things.
partially have images ready to document the change as well.
UPDATE 02May24: Sourced a "bracket" from a local you-pull junkyard as well as ordered supporting pieces from DF.
One hurdle i have tripped on is the change from one size to another in the bolt size for one of the master cylinder ports.
UPDATE 10MAY24: most of the process has been posted below, if there are any corrections please add to the thread and I'll edit posts as necessary, Thanks : D
