V1 Front Radiator Tubes
jirwin
jirwin
Can someone take a picture of their frame where the radiator tubes exit the frame at the front? I think my frame is messed up and is missing the front holes pictured here:
jirwin
Thanks Lonnie. I wondered if it was a revision or something. I assume this kinda changes how the front formed hoses are mounted?
ccannx
Video was spot on except for the frame change. If your building an ss/sc consider mounting your heat exchanger before your radiator it was sorta difficult to work around.
jirwin
Mine is N/A, so that shouldn't be a problem. I'm genuinely confused though. Here is what I am working with...
These are the hoses I have available:
10155
I tried running the 1st hose from the top of the radiator to the drivers side frame rail and it just looks wrong:
10156
10157
That basically leaves me with the ~ 30 degree bend (2nd in first picture) for the passengers side, but that looks wrong too. For one is doesn't match the video (1 bend vs 2), but it also looks like it will kink. I miiiiight be able to get that one to work though.
10158
10159
Just playing around with it logically, using the double elbow (first in first picture) to go from the bottom to the passenger's side makes sense:
10161
But then I really don't know how I would get from the top to the passenger's side. I can use that third funky looking elbow to get around the brake likes and such, but it would require an acute 60 degree bend to get into the passenger frame rail:
10162
I'm very confused to say the least.
Karter2026
I used two of the top hoses Dayco 71796 in your first picture. used them for top and bottom hoses in the front. I did the reverse flow on my car. Hot water in the top of radiator cold out of the bottom. So even if I get a air pocket I still have coolant flow. 600+ miles no issues.
This is how I have mine set up Tony had better pictures http://dfkitcar.com/forum/index.php?threads/tonys-city-goblin-2010-ss-tc.232/post-11574
jirwin
Which side of the car is hot and which is cold?
jirwin
I owe ya one @Karter2026 . That worked perfectly. I couldn't find the exact hose, but I found one that was basically identical but 2 inches longer. Used that one on the bottom and the 71796 from top to passenger side.
10168
10169
