MJP61
- MJP61 Well-Known Member
I am looking to sell my DF Goblin #297. Bought in March 2021, delivered in June 2021, completed in August 2021 and Titled and registered (Montana) in May 2022. I haven’t been on the forum in a while, so not sure what the demand is. Message me for any details or questions.
Built with all new parts. Only thing from donor car was motor, tranny and wire harness. List of all parts below.
2.2 Ecotec (LAP)
4 Speed Automatic Tranny
2.2 Ecotec (LAP)
Goblin Parts List
- Rear wheel bearing (Cobalt Front) Timken HA590069
- Front wheel bearing (Cobalt Rear) Timken HA590067
- Rear lower control arm (Cobalt Front) Moog RK620897/RK620898
- Serpentine Belt Gates K050345
- Transmission Pan Gasket - 24203590
- Transmission Filter - 24221762
- Axle Seal - 24203910
- Positive Battery Cable - 88987140
- Negative Battery Cable - 88987148
- Water Pump – Gates 43529
- Timing Chain kit – Cloyes 94201SAVVT1
- Balance Chain kit – Cloyes 94202S
- Timing Cover Gasket – 24435052
- Harmonic Balancer – 90537704
- Front Crank Seal - 29616
- Thermostat – Stant 14698
- Coolant Temp Sensor - 2134514
- Valve Cover - 12614738
- Front Tranny Mount - 25973863
- Rear Tranny Mount - 25973870
- Tranny Fluid Hose – 15817233
- Oil Dipstick tube – 12625480
- Oil Pressure Switch – 12635992
- Oil Filter – PF458G (12605565)
- Spark Plug – AC Delco 41-103
- Belt Tensioner – Gates 38177
- Starter – (Reman) Quality Built 6947S
- Steering Rack – AC Delco 25956924
- Steering Shaft – GM 15800140
- Front Inner Tie Rod – Moog EV80445
- Front Outer Tie Rod – SKP SESF305 (Moog ES2382)
- Rear Inner Tie Rod – Moog EV80445
- Rear Outer Tie Rod – Moog ES800030
- Turn Signal/Headlight Switch – Standard CBS1202
- Fuel Filter – Hastings GF372
- TPMS Sensors - AC Delco 13598771
- Fuel Cap – AC Delco GT283
- Axle (2) – Trakmotive SN8026
- Coolant Resevoir – Dorman 603059
- Front Pads - Centric 105.09560
- Front Rotor – 11” rotor with 4 lug holes drilled in by DF (BR900498)
- Rear Pads - Centric 105.09560
- Rear Rotor – IAP BR900646
- HOSES : AC Delco 26624X – Thermostat to union Driver Side Rear
- : Gates 3270 – 1” heater hose for lower frame tube
- : 72049 – Cut twice for rear hoses
- : 70846 – Lower Radiator
- : 22271 - ????
- : 18701 – heater core bypass
- : 70989 – Pass rear upper hose
- Tail Lights – Maxxima M85417R
