limp mode/3rd brake/dtc codes
SeanH
I don’t have evap. Can that cause the issue I’m having ? I don’t think I have a boost leak or something wrong with the car because the first drive this morning on one of the tune files I get a solid pull in and get over 20 psi, then limp mode reguardless of what I change. Do I need to disconnect the battery and reset things that way ?
SeanH
Found a decent leak and a small one, the bolt hole for stock map won’t let the bike pump the system much more then 12 psi before it drops to 0. The plate where the evap solenoid was (was broke I covered with epoxy) has a small bubble
SeanH
And the hose to the break booster leaked. Fixed and guess I’ll load one of the previous toons and start from there tomorrow
Turn on the P0234 code and see if it sets when you lose boost.
If you will send me an email address I can forward some other emails that have my HPT settings that I have sent to someone else. I'm at work and it can be difficult to attach files from this computer.
