Bigfoot Goblin
- Desert Sasqwatch Bigfoot Goblin
Before anyone jumps - yes, the fuel filter is integrated into the LNF fuel pump. What I'm asking is has anyone taken their pump apart to inspect the fuel filter and - more importantly - located any source for replacement?
The filter is more of a fuel pickup than a filter, like a Holley pickup 'sock'.
The filter doesn't have a PN on it and from all research the LNF fuel pump doesn't exist anymore as a new part. So looking for replacement filter appears to be out of the question.
So an inline filter is probably the best bet? I'm worried about the fuel out here, since we tend to get dust storms where the 'talcum powder' dust gets into EVERYTHING. I don't want any of that ending up in the high pressure pump and the stock filter is definitely not up to the task.
Next question: does the top of the fuel pump need to be modified to install? I'm test fitting and see the hole in the flange on the top of the pump doesn't line up to center the pump in the fuel tank hole. Enlarge the hole or ???
Has anyone added any fuel tank foam to help with the LH turn fuel starvation issue? My idea is to put the foam on other side of tank baffle to slow the migration of fuel away from the pump side of the tank. Yes, no, maybe? I have not used tank foam before and am looking for someone who has experience with it for an answer.
