phaetonman7
Member
- phaetonman7 Member
So i am having an issue with a no crank from the key. when you turn the key on everything is working. The fuel pump primes and the dash lights up and the lock lights for a couple seconds and goes off. I was able to remove the crank relay and jump the circuit and it will crank and started. I checked the wire from the ignition switch to the bcm and that is good. i checked the wire from the ecm to the fuse panel and that is good. i have switched the brake switch connector and the clutch connector with no change. i removed the ignition switch and pulled it apart and it was clean inside ( i remember someone having an issue with that). I went through and checked that all the grounds are connected. It starts and runs fine when i jump the relay so that tells me that side of the circuit is fine. I am just not getting the signal from the ecm to the relay.
