jirwin
- jirwin Goblin Guru
Hey guys, I've finally gotten around to turboing my little 2.2L and I need help figuring out a PCV system for it. When it was supercharged I vented everything to atmosphere, but with the TVS that started to become a problem when I got into higher boost. It was pushing oil out seals from too high of crank case pressure.
So... I'm switching back to a full PCV system and I need help designing it.
I believe this is the stock 2.2L (or any Ecotec NA) setup:
This is how I have mine currently. The LSJ intake manifold does not line up with the PCV hole in the head of the 2.2L LAP, so its effectively blocked.
This seems to work ok, but I'm not sure how well it works under cruising conditions. I was thinking about adding another line and a check valve like so:
I'm thinking that this would work, but I'm not 100% sure since technically its bypassing the throttle body. It is metered air since its post-MAF (I think that's how that works). The idea would be that under cruise/idle conditions the intake manifold connection would have higher vacuum and pull air thru the check valve and thru the breather. It might bypass the turbo and charge pipe but that shouldn't matter because its still metered air post-MAF. Then, under boost the intake manifold would pressurize and the check valve would close. The crankcase would begin to pressurize and the existing route from the breather to the turbo inlet would pull any pressurized crank case gases out, and back into the turbo, intake, and eventually engine. Does this make sense? I think it would work.
P.S. In my diagrams I have left out the catch can for simplicity.
P.P.S. If anyone knows how the PCV system works on the stock LNF I would love to see a diagram.
