V1 Ripped a inner CV up.
Oldchevyguy
Oldchevyguy
I just started driving my car. Supercharged LSJ with big injectors, small pulley, etc. I got a little aggressive. Wound out first to 6 grand, then banged second. I happened to be crossing a highway, and the highway was crowned a lot. The suspension lifted just as I hammered it. It broke the left inner plunge joint. I was a couple miles from home, and bbn it still moved, so I limped home about 15 mph. The CV shafts were stock with about 200K miles on them, so I dont feel too bad.
I ordered stage 1 shafts from ZZP. Now I wait! Jesus that car is fun to drive!
Glad neither you nor the Goblin were hurt.
The cool part about building these things is you are keenly aware of noises, vibrations, and smells. And immediately know where the weird stuff is happening and how to fix it!!!!!!
George
Both axles are the same length. sso I concluded that the inner drivers should be lined up with the subframe equally on both sides. I machined a spacer to fit between the engine mount bracket on the right and the cylinder head. and slotted the mount on the left.
Oldchevyguy
Interesting thoughts. If mine is off center like yours was, I have an alternative idea. How about if I machined a spacer to go in between the outer cv and the inner surface of the wheel bearing? Less cv nut thread would show. That would effectively lengthen the CV shaft. What do you think?
George
I had extended the lower ball joint 1.3" to lower the car and have the rear roll center a little higher (too much thinking, have since went back to stock and it is working better) That let me have a rear ground clearance of 5" from the subframe. This caused a very steep axle angle.
Brad
