There is front suspension footage to follow on the DF YouTube channel.I believe I’m at the point where I insert “I’m out of build videos”
A dab of spray foam could seal that heat leak. Don’t over of it, just enough to make a little wall/dam to stop the flow.With the new shifter from DF I discovered another heat source. The opening in the tunnel where the shifter cable come up is introducing hot air. Problems Problems Problems.![]()
