Fenix Nexen
Got the knuckles separated using the bolt trick and installed the coilovers
I don't know what the benefits of a rear sway bar is and would love a pros and consIf you want to run a rear swaybar at some point, you may want to swap sides so the swaybar mount is to the rear with the knuckle mount out.
I do want to do spirited driving. I have no experience with rear engine vehicles and no experience handling oversteer either. If a sway bar helps then I'll most definitely use itRear sway bar without a front should move the car more from understeer toward oversteer. In my case with the rear non-ss swaybar, it seems the car is pretty close to neutral with maybe a slight bias toward oversteer. Quite a lot of factors figure into this and I barely ran the car before I added the swaybar so I can't really compare with and without. But for spirited road driving a like where it its at. I can't comment on more aggressive race course driving.
The spacer is coated black nowSomething looks off on the top of the coilover assembly: http://dfkitcar.com/forum/index.php?threads/coilover-options.764/post-13095
Oh okay good to knowFor what it's worth, I am a spirited driver making more power than you will, @Fenix Nexen and I don't really experience either understeer or oversteer, to the best of my knowledge. I don't think it'll really be much of a thing for street-only.
Like I said, there is a lot of other pieces that go into this, such as wheel/tire combo and even alignment settings. And of course, even the how tight the roads are where you are doing your spirited driving will make a difference. I would make sure the coilover is done in such a way that you can add in a swaybar so you can easily add one later.Oh okay good to know
Is it because there's nothing else attached to the coilover that there's a gap between the spring top hat and the spacer? Even at full droop I don't have a gap there. Sorry if I'm making a fuss for nothing.The spacer is coated black now
Yeah that's what I'm thinking. Will see what happens when I get the rest of the stuff onIs it because there's nothing else attached to the coilover that there's a gap between the spring top hat and the spacer? Even at full droop I don't have a gap there. Sorry if I'm making a fuss for nothing.
Spring will likely need more preload.Is it because there's nothing else attached to the coilover that there's a gap between the spring top hat and the spacer? Even at full droop I don't have a gap there. Sorry if I'm making a fuss for nothing.
Multiple reasons to swap them so I will be doing that. I measured 4.5 inches deep into the strut just as the assembly pictures shown. Will see how it's loaded when everything is attached but atm stuff is at powder coating for a few weeksEven without running a sway bar, you should switch the sides as it will also give you a mounting point to hold the parking brake cables. You can see on the sticker FL for Front Left.
As @Rauq also mentioned, a good starting point is to thread the spring perch up to take all the play out of the spring at full droop and then thread in the bottom housing for ride height. Most start at ~4" measured inside the knuckle housing to the bottom of the shock insert.
Joe
Maybe. I'm tinkering on some parts right now and the front tie rods seem to be rusted on. Tried elbow grease and it's not budging. Front what I understand the front tie rods are used in the rear?Maybe the adapters to use the stock struts?
This is correct.Maybe the adapters to use the stock struts?
