Mikes Extended, Full Frame Goblin - 2009 Cobalt LS with 135k donor
Injector duty cycle is the duration that the injector is open, compared to the duration available.
For example, a 4 cycle engine running at 6000 rpm, has an available duration of 1/50th (.02) of a second for each cylinder to go thru all 4 strokes.
(6000 rpm = 100 rps, and it has 2 revolutions available for each cylinder power stroke)
The available .02 of a second may have the injector open for .01 of a second, which would give us a 50% injector duty cycle.
If the injector is open for .02 of a second, it would have a 100% duty cycle.
This is true whether is it a big or small displacement cylinder.
This is true whether is it a 1 cylinder lawnmower engine, or a 28 cylinder airplane rotary engine.
mike_sno
Does that mean HP Tuners is right or wrong? :D
I have watched a few youtube reviews and modifications of this $29 PQY Fuel Pressure Regulator with boost reference.
I was considering buying it, as I will need a BRFS.
Now to decide if the stock fuel pump can keep up, or if I need a new one.
I would note too that all three of us have flow-through fuel setups. I've not logged a comparison between the two (and I've only rudimentarily logged my current setup) but theoretically having the regulator after the fuel rail should result in more reliable fuel pressure when compared to a stock-style setup with no return on the fuel rail. BRFPS that OTTP and ZZP sell is closer to stock-style than our setups.
For clarification, I would consider (what I understand of) the LNF to be a true deadheaded returnless system where there is no fuel return line outside the fuel tank. All other Cobalts (I believe) at least have a return line at the fuel pump module, although returning from the filter to an in-tank regulator isn't much less deadheaded of a setup. ZZP and OTTP's BRFPS put the regulator external to the tank, but if the return still isn't connected to the rail somehow, fuel still enters the rail and stays there until it's used. A true flow-through return style setup will require a fitting to be added to the fuel rail, but with this setup and with the regulator after the fuel rail, fuel pressure in the rail should always remain where the regulator wants it to be (assuming the pump can keep up), without the regulator having to react to pressure drops in the rail.
mike_sno
I saw for the first time that you could connect the return line behind the fuel rail. What kind of connector is it at the end? I currently have a cap on the end. I ordered the BRFPS system with an set of AN6 connectors and hoses.
Are you saying that if the regulator is behind the fuel rail you don´t need the boost reference? I think that´s not correct. It is in my understanding not important that the fuel pressure on the rail maintains the same psi. It is important that the psi difference between the fuel rail and the intake manifold maintains the same. However, I see one big advantage of having the regulator behind the fuel rail, you could get cooler fuel to the engine.
I have no clue how, but based on what you said I understand it that the fuel filter is some sort of pressure regulator? Is this correct?
46579
Now my BRFPS has no manual or nothing. No clue what to plum where. It has 3 conectors, left, right and bottom. The right one is closed at the moment. I thought I had 1 from the fuel pump, one which returns to the tank and one go to the fuel rail, if installed before. But now I am thinking more I only need 2. Like this one, just no idea which 2 I would need.
46578
And I still need to know what kind of fitting that would be at the end of the fuel rail.
I believe this is the fitting that gets you an extra fitting on an LSJ fuel rail.
Sorry, I think my focus wasn't clear. The theory I have read is that fuel pressure regulators are more effective at maintaining desired fuel pressure (whether that's static or dynamic) if they're after the fuel injectors versus before them, as if they're preempting drops in fuel pressure versus reacting to them. Cooler fuel in the rail is also theoretical, as you also end up dealing with fuel returning to the tank that's been through the fuel rail.
To install the BRFPS in any configuration, you'll need to remove the in-tank regulator (assuming your fuel pump module is the set up like an LSJ's). You can use ZZP's instructions for this, reference the Manifold Regulated Fuel Pressure section.
We can also point you in the right direction on the rest of the install depending on which way you want to go. Sorry for muddying the waters, I know I also don't do a good job of putting together singular cohesive thoughts all the time either.
Dale E
Fuel pressure regulator set up in google images and on YouTube channels. Have a look. Pretty self explanatory. In your build log post #194 you have a picture of your fuel filter, which is a return style. You will remove this if you put on a pressure regulator and put on a straight through two port filter. Some of those three port filters are simply return style and some like on an older Corvette have a regulator built in. I believe the Cobalt has a regulator incorporated with the in tank pump, so that as @ Rauq said gets removed? The fuel goes from pump to filter to fuel rail to pressure regulator and back to tank. Or tank to filter to regulator to fuel rail and out from regulator to tank. Depends on if you dead head or return style system hook it up.
Check all the google images and some YouTube videos and pick one!
mike_sno
Took me a little while, but this morning I took out the fuel pump and want to replace it.
A few things which i noticed:
1. The fuel pump is just pushed into the fitting, no other support. It pretty much hangs on the supply line. Right?
2. All connectors are submerged and not necessary water proof. (I am not sure if gas or E85 is conductive or not. Guess not, but still was wondering)
3. S and R on top of the assembly by the hoses means: Supply an Return?
4. The return line is inside the tank connected to a gray plastic part. When using an external boost reference fuel pressure regulator this can be removed completely and the return line ends "free" in the tank?
5. My fuel pump is not an drop in replacement. The electrical connectors does not fit. How do you connect the electrical lines in the fuel tank?
1. I'm not sure, but I think this is normal.
2. I noticed that too, and wondered why cars don't explode with open electricity in the gas tank... The amount of conductance of gasoline must be minimal.
3. Yes, Supply and Return.
4. Yes, the stock 60PSI restriction/regulator is inside tat gray plastic part. Your BRFS will have an adjustable restriction, so you just need a free flowing return to the gas tank. Using the stock regulated return will prevent your BRFS from going below 60 psi, so that is why it is modified.
5. Here is the wiring for the LSJ fuel pump. Is your wiring harness from an LSJ?
Tell us what pump you have. You need the electrical connector, or else you could solder wires straight onto the pins, but that is not very convenient for maintenance and replacing parts. Once you have purchased the connector, just wire pin 1 and 2 to the pump motor, and pin 3 and 4 to the fuel sender. If you are using an LSJ fuel pump, here is a picture of how to bend the fuel sender.
Bigfoot Goblin
Electrical connections that are in firm (not intermittent) contact with no resistance are acceptable for operation in submerged gasoline (or kerosene - diesel, jet fuel, etc.). There is no free oxygen in the fuel to create a fire or explosion. Gasoline could actually drown out a fire if not for the vapors that evaporate from it that are the source of the combustion with atmospheric oxygen.
If the connection is not submerged in fuel, as long as no heat or spark is generated by the connection there is little chance of a fire or explosion due the highly saturated 'atmosphere' inside a fuel tank. Not enough oxygen to fuel vapor ratio (stoic) for this to happen. Note: this is why fuel tanks are capped/sealed.
Nearly every vehicle on the road has some type of electrical connection inside the fuel tank, especially newer vehicles with fuel injection. So to answer question number 2, yes this connection to the fuel pump inside the tank is correct.
mike_sno
@Ross I bought the QFS 450Lph pump. When lookin closer at it, the fuel pump is actually clamped in between this large black plastic part which surrounds the fuel pump. The lid is securing the upper fitting on the pressure side of the pump from getting off. I have to find another way of securing the upper fitting as the pump is a bit to high.
I cut the wires of the old pump and soldered them to the new pump. It’s working.
I looked at the pressure gray plastic pressure regulator and removed it. Pretty simple and nice design. Now I have it free floating back in the tank.
mike_sno
System is set up and I had the chance to tune it a bit. 2x reflashed and it is acceptable. The Siemens 60lb/h injectors, smaller pulley and E85 is running great. The BRFPS made all the difference to get the car in a decent idle, not perfect, but a LOT better than before! Confident that I will get it running great after a few more rounds of adjustment. Don’t see any true knock in the logs anymore.
Injector DC shows 90s at 7000rpm and I am running a bit rich. Seems ok for the moment.
I am sure a good tuner should be able to dial in the 60lb/h,E85 and smaller pulley without the BRFPS system, but for me taking out this one variable made the difference.
mike_sno
I am chasing a weird thing right now. The car every now and then dies when I hit the throttle. I am still in the investigation what the source could be.
This happens most when i turn left and the car starts to drift. I have not noticed it on right turns. I see that boost is there but the AFR gauge shows 22 which is the maximum it can display. I also noticed that it happens when the gas tank is half empty. It doesn't happen in higher speed drifts or if I just accelerate fast on a straight. It has never happened in any other gear than 1st.
My theory: The fuel pump is not getting enough gas or the bypassvalve is acting weird. I have not yet produced a log file to see what's going on. I tried once to reproduce it with a full gas tank but i wasn't able to. I am not confident that after one test with full gas that this is the source, but wanted to ask if someone had a similar behavior.
Gtstorey
It won’t take long on boost to ruin the engine if it’s running lean. It sounds like it maybe loosing all pressure which might save it though. But what you really need to worry about is when it is going lean but not enough to kill the motor.
