1988 Nissan B12 Sentra sleeper build
Goblinfanclub1234
We have the meats
54965
54966
54967
Goblinfanclub1234
After messing with 2 different sets of injector o-rings that were the wrong size I got the right ones in and have the fuel system set to 60psi. Both the fuel regulator and the Holley fuel pressure sensor are reading the same pressure.
I also had to change the o-ring on the oil pump and now have good oil pressure while cranking.
Also found out the hard way that Holley Terminator X does not like aftermarket crank and camshaft sensors so I am going to swap out for OEM ACDelco parts and try to start it again next weekend. Annoying.
