Add me too!Yes, let’s start a list. I don’t think we are to a point to start a group buy thread but I can keep a running post for people who are interested.
1. Me
2. @Peregrinus
3. @Fozda
4. @Towerdog
5. @OptimizePrime
6. @TheNuker ?
7. @Ark :D
8. @Lechlis ?
9. @WYGoblin
10. @comegetjoe
11. @Vwsaabvt
12. @Lokian
13. @Waterdriver
14. @JERMzSS
15. @AZmoto
16. @Lando217
17. @ATMironov
18. @Gtstorey
19. @JBuild
20. @PaulPerger
21. @Sparvy
Everyone else, reply or send me a private message to let me know. I will put you down on this list. Once I get an idea of actual cost I will start a separate group buy thread where we can confirm actual orders. This is just for interest and to try and get multiple done at one time to lower cost.
Some people have added spacers under the wings of the shifter mount on the tunnel cover to stiffen the entire assembly up, if that makes sense.Do you think there is too much flex in the tunnel cover when shifting to 5th and reverse. Maybe I’m just overthinking this. Probably fine.
Awesome!! Can you feel the improvement from this?I stiffened the shifter base by adding 2 bolts that go down to the floor bars on the extended frame. At 19:50 in this video.
I went through your list yesterday and ordered all of the McMaster-Carr pieces. Ended up being $84 shipped.OK guys, I just looked online, working to put together packages for people that don't want to piecemeal it themselves, and I saw that the shifter has 9 offers pending.
I think everyone that has on offer in on the shifter should withdraw the offer or let it expire. I think if we get everyone together, we can get better pricing from the seller or get them straight from China.
We should have the pricing for the base worked out in a day or two and I've found a separate supplier for the rod ends and ball joint linkages that cut a lot of the cost for those items out, if they're bought in bulk. Just hold for a day or two and it'll make it better for everyone. I think I can save everyone a lot of money on this thing if we all work together.
Thanks!
If the pattern is so tight (or to tight) maybe a longer shifter handle might be a better option to get it up higher vs the 3/4" plate? That would increase leverage slightly and it may be easier to come up with a better (stiffer/reinforced) steel plate that replaces the stock mounting plate completely. I received my shifter yesterday, but barely had time to look at it, so I don't know how much work would be involved with a longer shifter, although a hex adapter on top would add 1"-1.5".
The side to side force is controlled by the spring on the shifter so it's possible that a lighter spring could be installed.
I unfortunately purchased the shifter a week ago but I am still very interested in purchasing the base.OK guys, I just looked online, working to put together packages for people that don't want to piecemeal it themselves, and I saw that the shifter has 9 offers pending.
Thanks!
I did the same thing. Already got the shifter but was waiting on ordering the rest till the base was done. I figured I would lose the small stuff but the shifter is, hopefully, too big for me to misplaceI unfortunately purchased the shifter a week ago but I am still very interested in purchasing the base.
Hey Sactx,
I Followed you here from facebook on getting my ass on that list! Was going to order the shifter today, but see I should just wait so I will do so. However just make sure I'm added!
