AIM MXG 1.2 Dash
ATMironov
Has anyone tried installing a AIM MXG Dash in a Goblin. Expensive but would off the chart on the cool factor.
I wonder what it would take to do it?
@Brian74 has one installed.
My frame gets delivered this week and I'll be putting one in!
Mostly its plug and play. There are a number of inputs that the MXG can't read though the CAN Bus, so you will need to wire them in with remote inputs.
This is my list of warning lights that will need to be individually wired.
Hazards
Left Turn Signal
Right Turn Signal
Head Light Low Beam
Head Light High Beam
Parking Brake ON
Low Coolant Level
Check Engine Light
I also have 8-10 other sensors that I'll be wiring into the system
ATMironov
No, the MXG will report all the same data as the OEM cluster, so there is no need to keep it.
I did leave the wiring in for the cluster incase I have trouble getting it set up.
