Took the car to get an alignment today. The first NTB didn’t even want to touch it and kept giving me the run around so I had them call another NTB to see if they would and thank god there was a car guy there! He was all over it haha and he let me work on it with him the whole time!
My string alignment worked pretty good too I wasn’t to far off
I got some info from Lonny incase anyone else wants to know the specs they suggest
Alignment:
- Front
- Ride height: set to where the lower control arm is level to the ground with you (and a passenger) in it
- Toe: +.15 degree (toe in)
- Camber: -1.5 degrees
- Caster: 8.5 degrees
- Rear
- Ride height: Control arms level to the ground or slightly up toward the middle of the car. We normally end up with 7-8 inches from the ground to the lower lip of the subframe where the control arm slips in but this varies depending on tire size.
The more camber you can get front and rear, the better it will be for track use. However, while it is easy to add camber up front, the rear is a different story. Since we don't yet have adjustable top plates, the only way to adjust the rear camber is the method in the Cobalt service manual:
Basically you remove some material from the lower mounting hole of the strut to create a slot. Then you can get a little bit of camber adjustment.
I'd say maximize rear camber and then match that setting on the front.
View attachment 2646 View attachment 2647
