- Ark :D Goblin Guru
@ccgillett do you have Bosch MAP sensors? If so, what's the part #?
Manifold sensor is a GM part #12592016 (3 wire); charge pipe sensor is missing, I've ordered a Chinese knock-off 4 wire, or I could use an identical GM 3 wire one. Either way I gotta figure out where it wires in. I found some really bad photos online of somebody replacing a charge pipe MAP sensor in a Cobalt. From those photos I could get the wire colors...I will search the remaining connectors today to see if anything matches.@ccgillett do you have Bosch MAP sensors? If so, what's the part #?
Thanks! I can rely on the wire colors when though you switched sensor types, right?Ignore my map sensor looking different. I switched to 3bar sensors. This is the connector for the map in the charge pipe.
Map connector
The harness branches out into three separate legs of wiring. One is the MAP wiring pictured above. The other two are these connectors. I believe one is for the a/c compressor clutch and the other was for an a/c pressure sensor. (Not totally sure on the second one) both of those connectors are not used/unplugged on mine and just zip tied back.
It's unused neighbors
Hopefully that helps you find it now that you know what it looks like and who it's neighbors in the harness are.
I did thin my harness a bit (a/c, fan) but I don't think I had to cut back anything to make the MAP connector reach.Well gents, @Gtstorey @Mahkoi , I believe this is the plug...
View attachment 49476View attachment 49477
These connectors are all on the same wire group:
Assuming agreement then we're down to waiting for the new sensor and plugging it in. Looks like I might have to make it longer or do some creative harness trimming to reach the pipe.
You both have been really helpful and I'm grateful for that....
Would you need to swap both sensors (manifold and charge pipe) to 3 bar for it to work? The manifold sensor appears to be stock, including GM logo and part number.Based upon the color, it may been switched out to the three bar connector already.. This means the sensor you ordered may not work. But I’m not 100% sure. But the stock connector that I posted listed it as black and it is the same color as the swapped connector posted earlier.
